RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 10-06-2006 | 10:55 AM
  #5464
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
Hey Kostas1... Thanks.... Did you maiden yours yet?? Great job on your build!!
Let us know how all goes..
Hey, this is most likely no problem, But thought I'd just mention it.. On your ant. wire...
You know that it should not over lap itself.. and you should have "stops" I use cut
off smaller servo arms with 3 rod holes and snake the wire between two and if I going
to the top of the rudder, I use the thrid hole for the a rubber band to the rud.. On the
rec. side I slide that stop down the wire just before a bulkhead so as to prevent any
stress on the Receiver/wire from pulling out(not Good)..
It's also a good idea to keep it away from medal, along with no medal to medal contact...
Sometimes the reciever will have a mind of its own, and that sometimes can turn out not
to good..
Take this for what it's worth... Because it's from someone that still has to tape my ant.
wire to the wing [:@]... Otherwise I get glitches....... Have fun Kostas1...
