RE: Elevon Programming on a Futaba 7C
Deli conker
Just build the plane, install the servos.
Then connect all the servos to your reciever . turn the radio on . install the flight battery .
the servos should center. then turn every thing off.
link the control rods and hardware on the servos making sure that the control surfaces are flat.
now go to the elevon programming on the radio with the plane ON.
go to the ELE2 setting and pull the elevator stick full down. set the percentage to the maximum MECHANICAL throw the plane has.
Do the SAME for ELE1. i am not sure the direction of movement. you will have to play with that a bit.
Then do the same for AIL1 and AIL2 but this time playing with the aileron stick while changing percentages.
You have to use your plane as a point of reference for all this programming.
REMEMBER to set the maximum control throw on end point adjustment before all this.
Hope this helps
DAVIDE
Safe flights and landings!!
