RE: New HOW TO Posted: How to Install Robart Hinge Points
Good video. I drill a small pilot hole first, 3/32 will do witha hand held pin vice. Makes it easier to follow with the correct size. I also slip a 6 mill piece of poly sheet with a small hole punched with a sharp point in the poly. I slip this over the hinge point up to the hinge shoulder to further control the glue. After curing, this easily tears out.
