RCU Forums - View Single Post - New HOW TO Posted: How to Install Robart Hinge Points
Old 10-06-2006 | 05:48 PM
  #42
RysiuM's Avatar
RysiuM
Default RE: New HOW TO Posted: How to Install Robart Hinge Points
Got another giant plane hinged with Robart points. This time I used hinge pocket because I wanted all the surfaces to come out for maintenance.
The only new thing I did this time was the glue. I used recommended by Robart's glue. It looks exactly like yellow carpertner glue (maybe it is the same). I squeezed generous amount of glue inside the hole in balsa and spread it around so the balsa fibers were soaked with glue quite well. Then I wet the hinge point surface with the glue, just to make sure it sticks to the surface. Finally I set the hinge inside the hole. I could move it for about 1 minute before the glue started to be quite hard. Because my holes are quite tight, I could handle the surface after few minutes without worrying of dislocation.
Here are the surfaces with Robart points in there
ID:	536224   Click image for larger version
ID:	536225   Click image for larger version
ID:	536226   Click image for larger version
