TEMS adjustments
Adjusting the ATV's on the radio will not help.The TEMS will limit the pump delivery once the Max RPM is reached,and should this overshoot for any reason,the Turbine will be shutdown once the Shut RPM is reached.
The parameters which are not accessible on the TEMS are mainly the hold and shutdown EGT's and RPM's. All other parameters are limited by factory defined limits.
The ramping is freely settable, with minumum values to prevent a too quick a ramp up or down being set.
The idle RPM can be raised but not lowered(below 33K) , and Max RPM can be lowered,but not raised (above 126K) to allow the user to "derate" the thrust should he want to.
These values are for the TJT 3000, the PST has its own set of factory limits.
Hope this clears it up
Bruce Rattray
GB Hobby Electronics
