RE: which to get?
a old iron not your wife's or girl friends, with a old T-shirt for a pad works well for sticking the trim back on eventually it peels off at least mine did. work that sim to the bone try to make perfect landings it will all make sense when you get your plane in the air.
also don't bother hooking up the AFS like bruce has said . get a exhaust deflector it helps keep the slime off your plane one thing that I noticed was where the AFS sensor is on the bottom of my fuselage after a few flights fuel residue was soaking under the covering since I wasn't using the AFS anyway I removed the sensor and sealed the hole with white covering ask your instructor what he thinks. congrats your on your way !
