RCU Forums - View Single Post - The Mosquitos are here!!
Old 10-07-2006 | 12:32 PM
  #49
Seek and Destroy's Avatar
Seek and Destroy
Default RE: The Mosquitos are here!!
Ched, go [link=http://www.radioshack.com/product/index.jsp?productId=2431387&cp=2032062.2032402.203 2406&pg=3&parentPage=family]here[/link] and go to the part that says "Other ways to get it". Than click on the thing that says "Available at most stores, find it near you". Type in your zip code, according to it, there are a lot that have it here.
It helps to have people that live around the same place as you.
Micro, I just tryed it out again, it works but after a couple minutes, the motor dies. It's not the drivetrain. I can take off the gears and everything, and the motor is harder to spin than the other, better one. Should I try and lube it with WD40 or something? HOw would I take the motor out to lube it?
