RCU Forums - View Single Post - Kelly's Brio build and pictures
Old 10-07-2006 | 05:50 PM
kregan's Avatar
kregan
Default Kelly's Brio build and pictures
I thought it would be best if I didn't clog up Don's "Brio by the numbers"
thread with my first time pattern build so I am starting this thread.
I decided to use a OS 140rx in my brio and today I worked on the
motor mount and nose ring.
I purchased a Hyde A style motor mount. This mount does not require
a nose ring but I decided to add one in case I use a AR type mount.
I made the nose ring out of aluminum with fuel tubing installed around
the ring. I made the nose ring support out of 1/8" aircraft ply.
Here are a few pictures.
ID:	536656   Click image for larger version
ID:	536657   Click image for larger version
ID:	536658   Click image for larger version
ID:	536659   Click image for larger version
