Ok just made it back in...
I was pleased too find out that the wing not being all the way against the Fusalage was indeed the problem, I didnt notice it on the maiden flight but after that experience, I saw it. The rear clip will not pop in like the front.
Hence the tremendous lift I was experiencing.
It still isnt fitting perfect for some reason but it is flying level now!
One side is not tight and is causing the plane too turn a little one way but with a little sanding on the Fusalage that will be fixed also!
So the problem has been solved!
