ugot2luvit
I just started to do the break in on my Force .25 TC last night...Its brand new from the ground up...All the new parts were bought over ebay at the end of last summer...I got the engine from the RC house at a very good price...
But mine is pratically all new stock parts...And cost me around 250 bux to built...I allready had all the A arms for it and shocks and stuff like that.....
YOu can see pictures of it in this forum if my memory os correct.....
I ran 3 tanks of fuel in it last night and 2 more tonight but had to stop cause my receiver battery went dead on me...
To start mine I use a cordless drill.... I removed the pull start unit and found a 12mm socket 1/4 inch drive with long 1/4 inch drive extension....Then i drilled and tap a hole in the side of the socket and inserted the pull start one way bearing in it and put a set screw in the taped hole and VIOLA....
I had to remove some metal of the socket in order that i would fit behind the engine ....But it was well worth it... no More blisters for me....
