RE: Substitute for Ether
A reminder of my and others comment re the modded vegi oils as lube, we found that reguardless of the ether content our motors were easier to start than with the same mix but with castor, this may be of use were you need higher compression to start then when running, may also help the throttle responce( my tests were with a non throttled motor)
I think the modded vegi oils need consideration in your tests.
Stewart
