RE: unmatched cells
If you keep the disharged amount less than the smallest capacity cell then you have no problem. If you happen to discharge any more then it will definately reverse the voltage of the low capacity cells and hurt them. That is quite a large difference. I'd advise somehow trying to at least match the nominal capacity.
