RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 10-08-2006 | 03:52 PM
  #4327
chopperdudes
Default RE: E-FLIGHT BLADE CP
darn! settup problem. crashed it while accidentally flipping a switch, i think it's throttle cut or something. (my stick was up high and i had throttle cut on, then i accidentally flipped it off, so it just suddenly spun up and bit my cupboard. i got th-hold set up so all i lost was a set of woodies. however, i did set up teh revo and now, even with extreme throttle changes, the tail will stay about the same place. i had my low on 0 and high on -65. what i mean for the mix is that how do i mix in alittle more throttle to compensate for the extra drag i produce when i pull extreme cyclic. what i mean is that the mixes only allow you to program between channels, but for say, rolling is done with 2 channels (1 and 6 i think), and elevator is done with all there servos. (1, 2, 6) so how do i mix lets say, between throttle and aileron?
