Sorry but did you notice that the ad said the plane was designed for an intermediate or advanced pilot and not a beginner? That basically means it is NOT a plane to learn to fly with.
Since you already have a transmitter and want to keep the cost down BUT reliable I suggest the following.
http://www2.towerhobbies.com/cgi-bin...&I=LXCAS2&P=ML
http://www2.towerhobbies.com/cgi-bin...&I=LXK971&P=ML
for an engine use
http://www2.towerhobbies.com/cgi-bin...p?&I=LXBY18&P=
http://www2.towerhobbies.com/cgi-bin...p?&I=LXFMD5&P=
You did not state if you had a RX for your transmitter and I am also unfamiliar with the Hitec line of servos. However you should know that most brands of servos will work sith most brands of Receivers. Sometimes minor mods may be needed to the connectors.
