RE: Fliton Edge 540 Conversion
With the plane built to spec's, it is time for the power plant. I am using a Power 60 outrunner from E-flite. This motor swinging a 16X10 outputs about 1100 watts and gives incredible performance.
Using the X mount supplied with the motor, I outlined where the holes needed to be drilled. Now there are a couple of options available for mounting the motor. You could use an Aluminum mount from Atlantahobby or espritmodel.com. They are very convenient and come in different sizes. However, they are a bit pricey starting at $30.00. I have started using plastic standoffs when I can. I obtained these from Home Depot and they come in various sizes and diameters. Since the motor needed to be spaced 2" from the motor box to the rear of the X mount, I picked up 8 1" stand offs to form a solid 2" length. I also used some 3" bolts to reach from the X mount into the motor box. You could easily get away with 2.5" bolts, but they were out of them when I went. Just cut off the excess if you need too.
With the motor mounted, I choose to mount the HV-85 right against the motor box upfront. This put it directly in the airflow coming from the cowl. It should keep things nice and cool.
