RCU Forums - View Single Post - DA50 Dieing & Prop Question
Old 10-09-2006 | 09:16 PM
lsnover
My Feedback: (19)
Default RE: DA50 Dieing & Prop Question
ORIGINAL: srm99
ORIGINAL: lsnover
Hi Guys:
Been fighthing my DA50 in my Aerotech Yak all summer. Been very tentative on the needles, as I'm somewhat new to gas, and have been told SMALL adjustments. My problem is my engine would run fine on the ground in every attitude, but in the air, as soon as I got in an extended upline or inverted, or any extended snap maneauvers, the engine would loose power and threaten to cut.
I tried the "balsa box" solution from the Carb vent. No change. I finally turned the Low needle about a 1/8 turn richer, and now it seems to be doing much better. It will still start to loose RPM in a long upline if I'm below half throttle, but I can fly inverted and knife edge almost indefinately. I'm at the point where its starting to not transition as quickly to the high end. I'd like to resolve the power loss on the uplines and in snaps. How far can I push the low needle before I have other problems?
Also, this engine vibrates pretty badly. On my glow engines, I always mount my props in line with the cylinder at full compression, and this seemed to help with vibrations. I wanted to do this with the DA, but others have told me to mount it horizontal on compression to keep the prop. from stopping in a bad position on a dead stick. It would seem to me to be better to reduce vibrations MOST of the time, then to worry about the dead stick that MIGHT happen. Will aligning the prop and cylinder make much difference with vibrations on these engines?
Thanks!
Lee
i agree with bubblegates
plus how old is your motor as in the manual no extended uplines until run in thats 5 gal and how much airflow is the engine getting
Guys:
It's fine if I'm over half throttle, so I don't think this is a high needle setting. And the Hi is dialed back a bit from peak.
It's got about 3+ gallons through it, so it's still pretty new. I don't push it around that way frequently, because it is new. There's plenty of airflow. The Yak has a large inlet, their is a large cut out in the bottom, and their are holes in the fuse open for the canister muffler. The prop has been balanced carefully. I have a True turn spinner. I've never tried to balance the spinner and hub before.
Regards,
Lee
