RCU Forums - View Single Post - Engine mounting and Aircraft Datum
Old 10-10-2006 | 12:41 AM
efish
Default RE: Engine mounting and Aircraft Datum
Thanks everyone.
Darock - you're right, its a hard wood beam mount. However, the cowling provided is pretty generous lengthwise and isn't a really tight fit. I think I can shift it around a couple of degrees with no problems, then fix and trim (if required).
Another approach would be to make another cowl. Have been meaning to try my hand at moudling a fibreglass one.
Will go fiddle around and see how much a problem I have. Thanks very much for the heads up.
