ORIGINAL: opjose
I finally flew with my NX 1.00 today.
The "mount the engine sideways" suggestion did not cure the problem at all. It merely flooded out when I took a turn instead... sigh.
In my case it was NOT a problem with fuel delivery or tank mounting...
Rather the low speed limiter is EXTREMELY sensitive. 1/4 turn is enough to go from blathering rich and unreliable to a perfectly running engine.
In my case I had to turn the low speed needle to correspond EXACTLY where the limiter post was set to on the lean side +1/8 turn in.
This meant that I had to lean the engine out just slightly MORE than the factory setting.
Once done the high speed needed adjustment, and all was well with my 1.00NX.
Opjose, please understand this and get it through your noggin' - THERE ARE NO FACTORY SETTINGS.
If the engine is runnable out of the box with the stock needle settings, it is a complete accident. A serendipitous occasion, for sure.
You should have checked your settings and rectified them before asking for extensive help and suggestions, not that any harm was done.
