Chopper, sorry to tell you this, but you can't reuse the servo's that are inside the fuse, as I had mentioned they are run off a pot and are 5 wire, a normal 3 channel RX is going to use 3 wire servo's, this is where it starts getting complicated, you have to either build a new board to secure the servo's or mount them into the fuse and have the control horns on the outside to connect to new control rods or cables for the tail. Oh and the motor is a 540
. I know it's hard to wait but it's better than trashing it
