RCU Forums - View Single Post - Engine cuts out
Old 10-10-2006 | 05:02 AM
alan0899
Default RE: Engine cuts out
G'day Mate,
When you hold the plane nose up, does it increase revs slightly, If yes, it is rich enough, If not it is too lean.
Also the air bubbles in your fuel line, must be coming from a pin hole or other source inside your tank or fuel line from your tank. check it out, because this will cause it to run lean.
