RCU Forums - View Single Post - Will a Revo 3.3 run using Fuel with zero % Nitromethane???
Old 10-10-2006 | 02:02 PM
125cchyperman
Default RE: Will a Revo 3.3 run using Fuel with zero % Nitromethane???
I's sure it will run but you will not have nearly the power as the fuels with nitromethane. Nitromethane is what gives these little engine there power, and when you take that away from it it will run but be very low on power.
So I'm sure you can but you wont have the power that you would if you did have nitromethane.
