RE: Cox Christen Eagle
Servo installation is very simple. Cox even supplies servo arms that are already on the pushrods. I don’t know what servos the arms are for, I used Hitec HS-55’s and the arms didn’t fit. If you choose to use HS-55’s there will be no need to modify anything to make them fit. They fit the servo mounts perfectly. When installing servos into the fuselage, there are openings in the bottom of the servo mounts for routing the servo wires. This will guide the wires right to the receiver location. The HS-55’s fit nice and snug in the foam servo mounts Cox recommends that you install a foam wedge between the servos to help hold them apart. I used a piece of foam from the box that the Eagle came in. After servos were in place I used a drop of UHU foam safe glue on each servo tab just to make sure the servos were going to stay still.
