RCU Forums - View Single Post - sv Q
Thread: sv Q
Old 10-10-2006 | 03:41 PM
abjones413's Avatar
abjones413
Default RE: sv Q
BigMatt, I was wrong about the thin air making it leaner. I just found some great info for you, and anyone else having tuning troubles, due to a variety of conditions like temp, humidity, barometric pressure, altitude, nitro content, oil content and glow plug.
Here is the link to the site [link=http://www.*********.org/cars_eng-tuning.htm]Nitro Engine Tuning[/link] The following info can be found near the end of the article.
TUNING
This chart indicates the direction in which you should adjust the fuel mixture when faced with changing weather and other conditions. It assumes the engine is currently well tuned. You could face any combination of conditions listed in the chart; knowing which way to go with the mixture adjustments is half the battle.
Higher air temperature Lean
Lower air temperature Rich
Higher humidity Lean
Lower humidity Rich
Higher barometric pressure Rich
Lower barometric pressure Lean
Higher altitude Lean
Lower altitude Rich
Higher nitro content Rich
Lower nitro content Lean
Higher oil content Lean
Lower oil content Rich
Hotter glow plug Rich
Colder glow plug Lean
