RE: SV27 Battery Thread
what is your MV set to . some times you can have them set to low and you will not get them to peak , you have to have them abouve 5 to get them to top up . and a regualr 7.2 volt batterys will some times go more then the MAH and will end at about 8.5 or 9 volts , it is normal
