RCU Forums - View Single Post - Need a little help
Old 10-10-2006 | 04:27 PM
Dr1Driver
Default RE: Need a little help
That's cool, rc. It's just that I see so many trying it on their own and failing with considerable expense and frustration incurred. Didn't want to see you go the same way.
I can recommend these trainers:
The Goldberg Eagles
The SIG Kadets
Tower Hobbies Trainer
Any of the Hobbico trainers EXCEPT that POS, the Nextstar
The Great Planes PT series
Do you want to build or do you want an ARF?
You can fly from your cow pasture, provided it's smooth enough and has enough overfly area. You don't want to be flying over other's property, buildings, animals, etc.
I'm going to give you a REALISTIC estimate of the cost of getting into a .40 size trainer. I'll get a lot of arguement on this, but, in the long run, you'll see I'm right. Working with all new equipment, flight support box and equipment, spare parts, and AMA license (if their field requires it), you're looking at $400-$500 for a .40 size trainer. Now, before you have a heart attack... This is with ALL support equipment you'll need. Starter, glow driver, flight box, spare plugs and props, etc. Of course, if you can find GOOD used stuff, that cost can be cut drastically. Get someone who really knows to look it over before you buy.
Don't get the cheapest engine and radio offered at your LHS or online. Get something you can install in your next several planes. That will greatly spread out the cost.
Dr.1
