RE: finishing with Koverall or equivelant
gentlemen,thanks for the explenations since I am a true rookie with this process I still have some questions.You guys keep talking about dope can I use epoxy instead or is dope what I should use.what about sig stick it should I use this first and what is this product doing.If I must cut the fabric where do I want the to pieces of fabric to meet,also how do I blen dthe seem in.Is the nitrate dope what sticks the fabric to the wing and if so than why do I need to use the sig stick it product.Sorry to ask the question again but you would cloth the fuse but use less nitrate is that correct.also is nitrate the stuff that keepshrinking over time and has the tendacy to crack,If it is is there anything else I could use.Again thank you so much for your time putting up with a rookie finisher
sincerly,mark
