RE: running problems with OS 25 FX
Tried the new plug, but as you said, made no difference. [&o] Could it be a compression problem? It seems alright, is there a specific test I can do? I thnk I once saw a little fuel leaking from between where the main bearing is housed and the spacer that locks the prop in place. I only saw it once...could this be the cause and can I fix it? cheers again
