RCU Forums - View Single Post - Engine Trouble!
Old 10-10-2006 | 10:44 PM
Ron Olson's Avatar
Ron Olson
Default RE: Engine Trouble!
It could be a fuel pressure problem, a blocked pressure fitting or something. Try pulling off the pressure line from the tank and see if you can blow through it to see if it's clogged at the pipe. If that isn't it, pull off the fuel line and blow through the pressure line to see if it's pushing fuel to the carb.
If the boat has sat for a while, things can get clogged up with varnish.
