RCU Forums - View Single Post - some nomenclature:
Old 07-25-2002 | 08:43 AM
FHHuber
Banned
Default elevator repair
Sometimes you can get away with wood screws or sheet metal screws holding the lower nosewheel block (or the lower 2 screws if a single dual block unit) But you have to be CERTAIN that the screws won't puncture the fuel tank. (which makes a big mess inside the plane, besides making the engine not run correctly...)
Again... without seeing the damaged pieces... its difficult to give the best way to handle it.
I used to go ahead and fly a plane with a hinge lne causing flex in the elevator or horizontal stab... then I found out why my servo gears were stripping, and my battery pack was only giving 1 or 2 flights, and my tailplanes kept breaking at the fuselage. NEVER again will I pass a student's plane for further flight without it being repaired CORRECTLY. The chance of catastrophic failure is too high. The chance of the plane comming down in an uncontrolable condtion, possibly POINTED AT SOMEONE on the flight line or back in the spectators area isn't worth it.
Buy a copy of the Sept 2002 issue of Model Aviation. Read the District X Report. (page 166) His plane wasn't broken... I've seen planes shed control surfaces in flight and come down HITTING people! Luckilly the ones I've seen just resulted in minor bruises....
