RE: Engine Trouble!
My fuel lines are all working correctly, I took the pressure line off the exhaust and blew into it and it blew freely and pushed fuel through the fuel line up to the carb. Is there something I could use to clean the needle up? I am going to try my Mac pipe on it to see if it is the pipe that is the problem. It is a wierd prather silenced pipe and I drilled out the "predrilled" hole to fit a tad bit larger pressure fitting. I will give a pipe switch a try tomarrow and see if that helps.
