RCU Forums - View Single Post - Seagull Spacewalker wing alignment
Old 10-11-2006 | 05:44 AM
Calhob
Default RE: Seagull Spacewalker wing alignment
Thanks for your good advice, John. Actually, I found the misalignment wasn't as bad as I originally thought. I was able to fix it by slightly enlarging the bolt holes in the wing, moving the wing enough to align it and then glueing a small piece of plywood on each side of the trailing edge alongside the fuse to act as positive locators. Works fine!
