ORIGINAL: Phill H
i ran mine again at 150k. the thrust was around 15.5 or 16lb, egt 680 or something like that. the SFC was better than my first run.
Phil note the rpm you state and the thrust miles off the quoted figures even for an engine "you happend to have" with the wrong size tube!!
Also the so called production kit engine which was reviewed in rcji which had to be messed with by you JUST TO GET RUNNING could you tell us first off how many different combustion chambers you tried in it AND is this the type of quality engine/kit which was sent out to your customers because if you couldn't get it running anything like close to spec HOW THE HELL DO YOU EXPECT THEM TO but I suppose its just a case of reading your terms and conditions.
All the best
Ant
