battery charging
Hobbico has a new replacement for their Quick Field Charger, and I got to play with one the other day. Two separate chargers where you can manually set the charge rate, as well as a fairly wide range of cells it can charge on each port. It can also do NICAD, NIMH, and Li-Ions.
