RE: Evolution type 2 ignition
cmays02
Going to PCM just disguise's the problem does not get rid of it, most people who do it properly will fly on PPM first to ensure that a problem does not exist then switch to PCM to get the fail safe feature, so get rid of the ignition interference before going to PCM, make sure you do not have any metal too metal contact anywhere that is also a problem if you have the Rx far enough away.
Mike
