RE: NQD Hydro
I am going to have a good this weekend in striping some weight from my hydro but not replacing with coke cans!!!!
I need some other stats from you all as follows:-
total boat weight all up ?
single or double motor drive?
flexishaft or striaght shaft drive?
Prop type diameter and pitch?
motor size and free running rpm?
battery pack size ie volts and Amps?
battery pack weight?
motor weights close as possible?
current estimated speed in the water?
Cost of hardware ie motors, controller, batteries but not radio gear?
Can any body help.
From this information we should be able to select the most appropiate setup in terms of hardware, prop, motor, shaft pitch etc. this should also help other new users of the NQD speed storm
