RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 10-11-2006 | 06:23 PM
  #3376
FERNDALE AIR FORCE's Avatar
FERNDALE AIR FORCE
Default RE: Air Hogs Aero Ace!
Patrick, the aa jet is faster and needs more room to turn. Other than not climbing, what does your bipe do? Is it porpoising? You might try a little down elevator, this helps trim the plane in some cases. As for the mono mod it's great. I used stir sticks to resupport the wing, but that is not necessary. If you carefully peel the lower wings off, you can put them back on if you don't like the mono mod.
DJ, I can't get a death spiral if that is what you mean. It is true though that if you turn hard you might need to counter steer a little. The reverse is also true, If your in a climbing turn you can steer the other way fo a second and then return to your original turn. That often creates a stall turn with a flare out to regular flight.
Neuro, that could well have been built for spinmaster. On the tru website the have artwork for a stealth dominator that looks like that. I won't order one unless I'm sure it isn't the old non dominator. Tim
