ORIGINAL: Patrick_W
It is porpoising, and it is just plain not climbing, espicially later in the flight... if i take off the lower wings, will the decreased wing area make it have a harder time climbing? im about to *carefully* rip them off...
Could be too much up elevator or motor shafts are dirty. Usually tiny dirt strings
wrap themselves around the shafts and slow down the props.
Another thing you could try is adding weight to the nose.
ORIGINAL: micro_builder
Neurotex, you're right, that F117 looks like a perfect match for the AA. nice find, good luck on the maiden
nick
For about $10 with post, I couldn't pass it up!
ORIGINAL: FERNDALE AIR FORCE
Neuro, that could well have been built for spinmaster. On the tru website the have artwork for a stealth dominator that looks like that. I won't order one unless I'm sure it isn't the old non dominator. Tim
I've seen that one too and I believe it's the old Dominator type which is solid
soft foam. This F-117 from FlyZone is hard sheet 3mm foam.
