RCU Forums - View Single Post - Sig Somethin Extra questions
Old 10-11-2006 | 07:58 PM
jlimey
Default Sig Somethin Extra questions
Hi,
I just purchased a used SSE. The plane is in pretty nice shape, but I don't have a manual and could use advice from someone that might have a SSE.
First - what are the recommended throws for low and high rates. My son and I are definitely going to start on the low rates!
2nd - I have an O.S. .46fx that I was hoping to use on this plane. However, the current location of the mount means that I will need to carve away quite a chunk of the cheek for the needle valve and muffler to pass through. Anyone know the recommended mount location so I can double check it? Also, did you have to carve out the cheeks if you have an O.S.?
I think that is it for now.
Thanks for your time!
Jeff
