ORIGINAL: AKFireMedic
Makes sense. It can't be that hard so I'm sure I figure it out once I get started on it. What part number sulivan tail wheel are you all using? I piced the s860 as the most likely choice but I wasn't sure. Also, are most of you using the Du-Bro Long control arms for your servos? And finally, is anyone at or near sea level running a 15x4 on the Saito 82 and if so, is the main gear long enough to clear the prop? Thanks again.
Here's the Sullivan wheel I use.......[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFV47&P=ML]tail wheel[/link]
Yes, I use the Dubro long arms... They work great. A little spendy but work great.
For the prop. I fly at about 200 ft and use the 14x4w prop on the 82 and use a 15x4 on my 91.
