RCU Forums - View Single Post - Tri - to - Drag
Old 10-12-2006 | 06:55 PM
B.L.E.'s Avatar
B.L.E.
Default RE: Tri - to - Drag
I converted a Senorita that had flown a while as a trike. I ran a separate pushrod to control the tailwheel and countered the extra tail weght by removing the .25 FP and replaceing it with a .40 FP. Heck, if you need noseweight, it might as well be a bigger engine. I also added ailerons at the same time.
What I found interesting was that the bigger engine seemed to be no thirstier than the original .25 was, I suspect because it flew at smaller throttle openings most of the time.
