RCU Forums - View Single Post - Top Flite Staggerwing
Old 10-12-2006 | 08:17 PM
  #144
jimmkeeh
Default RE: Top Flite Staggerwing
FGPierce,
Yiour pictures seem to show that you mounted the 180se inverted. Is that correct?
According to the RCS website, the 180se is 5" from the prop centerline to the top of the plug. My Saito 180 is 4.4" so it should work inverted, also. Did you try to mount the 180se at 90 degrees? Do you know how much room there is for a 90 degree monted engine?
Soory to bother you with these questions, but you seem to be moving right along. I have only taken mine out of the box and looked at it so far. My job, seems to get in the way of my fun.
Jim K.
