RE: Main tail gear problem
Use a small touch of thread lock on the screw and don't tighten it to the point where you distort the gear. Don't overdo the threadlock as the nut sits in a hex recess that you can't get a spanner or pliers into.
Personaly I find that the friction between the screw and the plastic gear is enough to stop it coming loose.
