RE: Showtime
You can mix the elevator to the gear channel. Use mix 4. Then set your travels in the mix so they move equal distances. In the mix it asks you for a switch. Scroll thru untill it says always on. Now go into the setup mode that allows you to change models. As you scroll thru the options there is a list of switches that appears. Select the gear switch and you should be able to inhibit it. I believe this is what I did on my Funtana but I'll have to verify that later tonight.
