RE: monokote and acetone help
I use the windex technique, and once the trim is solidly in place, I use the covering iron to heat any sharp points, as well as tack down about 50% of any long edges (keep the heated area to about 1/8" wide, and about 1 inch wide. Don't heat a broad area, as it will cause bubbles to form and stretch the monokot.
Brad
