RCU Forums - View Single Post - Official HPI MT2 Thread
Old 10-13-2006 | 06:49 PM
  #8036
46u's Avatar
46u
Default RE: Official HPI MT2 Thread
Glade you got it running!!!!!!!! When you say the steering is tight not sure what you mean. There are several things that can go bad with a servo, you can strip the gears, mess the motor up or the circuit board goes bad. If the gears strip you normally well make a lot of nose and will turn to a point and stop. If the motor goes bad it will not do anything. If the circuit board goes bad it will act very irregular.
