RE: DA100 acting strange
Just a clarification - at 1,400 RPM and up the engine is fairly smooth on the ground. It's just below 1,400 it starts really jumping around - almost more like a miss than a loading up. Hmmm... maybe I'm still lean on the bottom?
Could be I have 2 problems? Maybe I should put a plate over the carb in case some air is blowing on the vent hole causing it to richen a bit in flight? Starting to think maybe I'm lean ont he ground and rich in the air - that would explain the symptoms I think.
I'd better check my ignition battery too ... any other suggestions?
