RCU Forums - View Single Post - Do fly it or not?
Old 10-14-2006 | 09:43 AM
aerowoof
Default RE: Do fly it or not?
what you have is aileron differential which is desirable on a flat bottom airfoil and will not cause any real problems on a chambered airfoil.if you have a computer radio you can fix it with programming.if not you can do it mechanically on the servo wheel.move the linkages from the 9 and 3 o'clock position to the 8 and 4 o'clock position
