RCU Forums - View Single Post - Do fly it or not?
Old 10-14-2006 | 09:43 AM
Mr67Stang's Avatar
Mr67Stang
Default RE: Do fly it or not?
Remove your control arms from the servo. Turn on the plane and transmitter and nutralize aileron trim. install the servo arms so the arm and the control rod make a 90 degree angle. readjust the clevise at the contol horn on the aileron so that the aileron is nutral. If you do not have a clevise on the aileron control horn and have a Z bend adjust where aplicable. if it is not adjustable replace the setup with adjustable control rods. Recheck for aileron differential.
