RCU Forums - View Single Post - Voltwatch problems..
Old 10-14-2006 | 11:05 AM
cooperd
Default RE: Voltwatch problems..
I've seen this also. It occurs when the battery pack is getting down on voltage in my case. My plane has large servos, two for AILs. If your battery is fully charge when this is happening, it may be that your battery pack is weak, incapable of putting out sufficient amperage without a large voltage drop. Check your pack with a digital voltmeter that applies a load as it reads the voltage.
