You might try the APC 15x4W
http://www2.towerhobbies.com/cgi-bin...?&I=LXFGW1&P=M
or the 16x4W
http://www2.towerhobbies.com/cgi-bin...?&I=LXFGW4&P=M
Just because the description says “3D” doesn’t mean that’s the only way to use it.
The 14x6 you’re currently using is a “Pattern” prop; whatever that means.
Using the ‘load’ numbers ThrustHP calculates, the 3 blade equivalent to you 14x6 would be a 14x4. Of course, you cannot buy a 14x4 three blade.
The 14x7 three blade has similar load numbers to 16x6 or 15x8 two blades.
